ARC Discussion Forums: Tamiya 1:72 M6A1-K Nanzan - ARC Discussion Forums
#1 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 02 August 2012 - 09:11 PM
This kit is 1/72 Tamiya M6A1-K Nanzan. Compare with her sister Seiran, I guess that most people may like Seiran more than Nanzan. I am one of them actually, but I think building this Nanzan is still fun. I don’t have the PE set for this build, but I am going to try adding some details on her.
deepbluemodel.blogspot.com
I found only few rivets on engine part of nose, so I wanted to have whole fuselage with rivets. Added rivet lines on wing first according to the drawing of Seiran.
Added rivet lines on fuselage as well.
This kit has seat belts, but they are decal. I used 0.025mm brass sheet and 0.15mm brass wire to make new seat belts.
Both instrument panels have some details, but I added more buttons and switches by stretched sprue and styrene rod.
I also added some details in the inside of cockpit. In addition, the floor in the back is kind of short. I extended it by styrene sheet.
Both inner walls of cockpit have some raised details. I still wanted to add some conspicuous details on them. This is left inner wall.
Right inner wall.
#2 User is offline   Hero Ma
  • Glue Required
  • PipPip
  • Member ID: 23270
Posted 04 August 2012 - 02:08 AM
:jaw-dropping:
At 1/72, your work is incredible! I see great things coming...
I may steal your idea to make the seat belts. May I also ask what do you use to fix the copper wires to the fuselage?
This post has been edited by Hero Ma: 04 August 2012 - 02:09 AM
#3 User is offline   blunce
  • Eyeballs deep in muddy waters
  • Member ID: 15168
Posted 04 August 2012 - 02:41 AM
Yeah, that's some great riveting, nice-n-straight, for 1/72. And the detail you are adding looks amazing! The Seiran has always been one of my favorites too. I didn't know this was essentially the land version of it.
#4 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 06 August 2012 - 02:36 AM
View PostHero Ma, on 04 August 2012 - 02:08 AM, said:
:jaw-dropping:
Thanks, Hero Ma. I use super glue to fix the copper wires only.
Thank you, blunce. As I know, only two Nanzan had been built. They were for flight testing and trainers.
#5 User is offline   Canuck63
  • Member ID: 7322
  • Location:Dunno really!Woke up one morning and found myself here!!!!
Posted 06 August 2012 - 08:09 PM
Positively,ABSOLUTELY SWEET! :wub: :wub:
Congrats
Lou
#6 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 08 August 2012 - 09:30 PM
Thanks, Canuck63.
New update is coming...
Began to paint cockpit. Airbrushed Hobby Color 6 green in the cockpit for basic color.
The front instrument panel only has raised small circles. I decided to apply the decal of instrument panel on each circle directly. Cut the decal of each instrument one by one and applied on appropriate position. Waited for dry and airbrushed clear paint.
Painted different colors on details of rear instrument panel. Moreover, applied the decal of each instrument and airbrushed clear paint.
I also painted the colors on switches, buttons and wires. Then washed both instrument panels by light gray and sand brown of oil paint. Dry-brushed with light gray oil paint. Additionally, used silver paint to make some chips and airbrushed flat clear paint at last.
I airbrushed two chairs with Hobby Color 405 olive green and seat belts with 66 sandy brown. After painted silver for metallic part, glued seat belts on chairs.
Washed whole chairs by dark gray oil paint. In addition, only washed seat belts by dark brown oil paint. Did the same chips effect with silver paint and airbrushed flat clear paint.
I also made the glasses on gun sight and compass by 0.2mm clear sheet.
Painted colors for details of cockpit.
Then did the …washing, dry-brushing, sliver chips and flat clear paint.
Put chairs on cockpit.
#7 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 08 August 2012 - 09:32 PM
Painted the details of left inner well.
Same process for weathering.
Painted the details of right inner well.
Assembled the cockpit.
#8 User is offline   blunce
  • Member ID: 15168
Posted 09 August 2012 - 05:18 PM
Wow! That looks awesome regardless of scale, but the fact that it is 1/72makes it that much better!
#9 User is offline   Canuck63
  • Member ID: 7322
Posted 09 August 2012 - 06:06 PM
Simply put......STUNNING! :jaw-dropping:
#10 User is offline   bdt13
  • Member ID: 11010
Posted 09 August 2012 - 06:58 PM
In the words of a famous Sith Lord to his son - "Impressive... most impressive!" :woot.gif:
#11 User is offline   ChippyWho
  • Pushing the envelope of mediocrity...
  • Member ID: 20977
Posted 09 August 2012 - 10:14 PM
Simply magnificent!
#12 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 10 August 2012 - 04:55 PM
Thanks for nice words from all of you !!
#13 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 18 August 2012 - 04:51 AM
I am kind of disappointed with this Nanzan, because the canopy is closed only. But the biggest disappointment is… there is a big gap between canopy and fuselage.
After covered the glasses of canopy by mask tape, I filled the gap by epoxy putty. After dry, I added some putty and ground smooth.
There are two triangle structures under the wing. Tamiya only engraves a simple slot on each triangle structure. For improvement the detail, I sawed the middle of the triangle structure. Then I drilled a 0.25mm hole near the top and put a 0.25mm wire into the hole.
I scribed the positions of flap fairing on flaps first (Are they usually called "flap fairing"? I am not sure, sorry...). Made the flap fairings by 0.076mm brass sheet and 0.8mm brass rod. Installed these flap fairings after painted the fuselage.
Next was replacing gray navigation lights. Cut navigation lights on both side of wing away. Glued clear rod on same positions and ground them becoming same shape as navigation lights.
Made a new pitot tube by 0.5 and 0.8mm brass pipes. The instruction shows that insert pitot tube in front of wing, but I found that pitot tube is installed under the wing on real airplane. Therefore, I filled original hole and added two small piece styrene rods under the wing for fixing pitot tube.
These exhausts are really small. I was afraid to break them. Thus I didn’t drill holes, I scribed a small slot on the head of exhaust instead.
The diameter of piston rod was same as main strut. I decided to replace by a smaller brass rod. Sawed the part of piston rod first. Then drilled a 0.8mm hole from bottom and inserted a 0.8mm brass rod.
Added break lines on landing gears by 0.25mm wire. Furthermore, the wheel doors were too thick. I made two new wheel doors by 0.127mm brass sheet.
Painted these small parts first.
#14 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 31 August 2012 - 09:46 PM
Began to paint the fuselage. I airbrushed the basic color of cockpit on canopy first. Due to there are a lot of tiny rivets on fuselage, I decided to airbrush the Hinomarus instead of using decal from the kit. Airbrushed white first, then red of the Hinomarus.
Because the Hinomarus under wing has white around it, needed to be more careful for masking.
Airbrushed Mr. Metal Color 218 alminume on fuselage first.
For some chip effects, I used mask tape and masking sol to cover some areas for keeping metallic color.
WWII Japanese aircraft usually had been primed the panel of aluminum by red primer. I airbrushed same color on fuselage. This color might show up a little bit after making chip effect.
This Nanzan is a trainer. Airbrushed orange.
Airbrushed underpart orange as well. In addition, added orange with a little bit yellow to have a different tone on underpart.
In the late WWII period, even Japanese trainer aircraft needed to go for battles or guard missions. They painted only upper fuselage green due to lacked of resources, kept underpart orange still. Therefore, I airbrushed only upper fuselage with Tamiya XF-70 dark green.
#15 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 31 August 2012 - 09:52 PM
I also wanted to have some sun faded effects on fuselage, so masked along panel lines.
Airbrushed light gray along panel lines, then processed second time masking.
After airbrushed second time light gray.
Began to make chip effect after added yellow to the leading edges of wings for identification strips. I used a toothpick and alcohol to remove upper colors on fuselage.
Made chip effect for underpart as well.
Washed panel lines with dark gray oil paint. Moreover, used several colors of soft pastels to emphasize light, dark and smudge.
Look close to wing.
Washed underpart by oil paint and used soft pastels as well.
Airbrushed flat clear paint on fuselage and clear colors for navigation lights after assembled small parts with fuselage. Everthing was done.
#16 User is offline   CorsairMan
  • Member ID: 8119
Posted 02 September 2012 - 02:16 AM
Whoa.. that is some way to finish a plane... I am very impressed! Well done!!
#17 User is offline   Anzo
  • Canopy Polisher
  • PipPipPip
  • Member ID: 21767
Posted 03 September 2012 - 10:06 PM
Thanks, CorsairMan.
I posted photos of finished airplane here. http://s362974870.on...howtopic=254484
#18 User is offline   bdt13
  • Member ID: 11010
Posted 03 September 2012 - 11:22 PM
WOW! This started great and made it to awesome!
