ARC Discussion Forums: Accurate 1/32 Mk. 82 bombs - ARC Discussion Forums
#1 User is offline   Brian J.
  • Canopy Polisher
  • PipPipPip
  • Member ID: 15552
Posted 03 July 2012 - 03:45 AM
I have three makes/versions of Mk. 82 500 lb bombs and am in a bit of a fix figuring out which is the most accurate.
I've read that the bombs found in the 1/32 Trumpeter A-4 Skyhawk are much too slender/thin and the "snakeye" variant is overly simplified.
I have made up a set of Mk.82s from the older 1/32 Hasagawa A-4 and they appear to have a better shape, but they too look a bit undersized (wish or hope I'm wrong).
I also have a set of Mk.82 Retarded Bombs (USN) from CAM (R32-020). The rear section is much more detailed than the Trumpeter interpretation but they are noticably thicker/fatter.
I checked out the Master Details site and they carry a nice looking version of Mk.82s. Unfortunately they sell for about $20.00 a pair! As I need 6 bombs that gets a little rich.
Has anybody done a build-up of a Viet Nam era model using Mk.82s? What was your take and what might you recommend?
#2 User is offline   Youngtiger1
  • What's the matter? CIA making you push to many pencils...
  • Member ID: 516
Posted 03 July 2012 - 04:23 AM
I don't have the CAM but between the Has. and Trump. I say go with Hasegawa. However, most accurate bombs are Academy sets out of F/A-18C/D kit.
#3 User is offline   Finn
  • Member ID: 2625
Posted 03 July 2012 - 04:44 AM
The Trumpeter Mk-82 w/conical tail bombs dia is actually closer to a Mk-81 250lb, they are too long however, if you can find a way to shorten them by about 5mm then you can some nice 250lbers which were quite common early in Vietnam. The Snakeye tails of the Academy F/A-18 are off, it tapers too much, only if Hasegawa would convert their 48 Weapon Sets into 32nd scale then there would be more than a few modellers.
Jari
#4 User is offline   Joe Hegedus
  • Member ID: 1761
Posted 03 July 2012 - 11:25 AM
I'm not sure that Hasegawa didn't put MK-81 bombs in their old 1/32 A-4 kit.
#5 User is offline   Brian J.
  • Canopy Polisher
  • PipPipPip
  • Member ID: 15552
Posted 03 July 2012 - 12:01 PM
I just noticed the post by Curt entitled "Notice anything strange" which includes a photo of a VF-111 F-4B dropping bombs. What type and size of bombs are these? They look much like the type found on the 1/32 Hasagawa A-4.
What a coincidence! I have converted the 1/32 Tamiya F-4J to an B using nose and tail resin from an old CAM set, along with numerous other aftermarket sets. I also want to do my build-up in VF-111 markings, the often done '201'.
I have both of CAMs 1/32 resin TERs and MER's and plan on using the TERs on the F-4B and the MERs on Trumpeters A-4. These sets look like they're on steriods compared to the Trumpeter and Hasagawa versions.
I have the 1/32 CAM sheet for this bird but the main thing holding me back is correcting the nose art/shark mouth. The CAM decals (a copy of the old 1/72 Micro Scale sheet) is incorrect. Poor shape and way too many teeth.
#6 User is offline   Finn
  • Member ID: 2625
Posted 04 July 2012 - 12:29 AM
The bombs look to be Mk-82s, here is another pic of the F-4B with bombs:
http://www.usscorals...ges/rt71721.jpg
Jari
