ARC Discussion Forums: Solvaset - stains - ARC Discussion Forums
Solvaset - stains
#1 User is offline   bikerider
  • Bikerider
  • Member ID: 22191
Posted 14 June 2012 - 11:57 AM
Hi all,
I have been using Solvaset from Walthers as a decal setting solution. The decals are applied on the model over a thin coat of future, then I use the Solvaset to help them settle down and apply properly. For the most part I have no problem, but on a recent model I am working on - Academy Mig-29AS with the digital camo decals - I guess I used too much Solvaset in places and now there is some white staining left on the model where the Solvaset liquid dripped and pooled as the decals dried.
I have tried using a damp cloth to remove the stain, but this is not really effective. Have others had this problem? What can I use to remove these stains?
Thanks for helping.
Kevin
This post has been edited by kevin.n.home: 14 June 2012 - 12:19 PM
#2 User is offline   STJohnson
  • Snap-Together
  • Pip
  • Member ID: 21068
Posted 14 June 2012 - 01:04 PM
I have had that happen too. I usually just give it another "light" coat of solvaset & it dissapears!
#3 User is offline   mynameismatt
  • Go 1/32 or go home!
  • Member ID: 2634
Posted 14 June 2012 - 04:51 PM
I've experienced the same problem. Another coat of future will make the milky white stain disappear.
#4 User is offline   bikerider
  • Bikerider
  • Member ID: 22191
Posted 15 June 2012 - 01:14 AM
Many thanks... I am glad to report a top coat of future removed the offending stains. Thanks for the tips!
Kevin
#5 User is offline   DutyCat
  • Gil Gregg
  • Member ID: 7952
Posted 15 June 2012 - 01:24 PM
Solvaset is also very powerful. I just ruined a set of decals last week with it. Stupid. Better to stick with the Micro Set/Sol combo for all but the toughest decals.
#6 User is offline   Netz
  • Where am I going, and what am I doing in this hand basket
  • Member ID: 2585
Posted 17 June 2012 - 03:13 PM
When using Solvset you really need to dilute it a bit, it's a very hot solvent, I just dip my brush in water then the solveset.
Curt
#7 User is offline   balls47
  • Member ID: 15452
Posted 27 June 2012 - 05:20 PM
I really like Solvaset. I use the Micro System, but seem to go back to Solvaset. I guess it's because it was the first decal solvent I ever used. Sorry, I have digressed. I also use Solvaset over Future. I put the Solvaset on the decal and then just slightly over the edge, onto the model, so it softens up the clear edges and fuses them onto the model. If I have the staining effect, I clean the area with water to make sure that the "rusty" looking stain isn't just dried Solvaset. It not, I do what you did and put a little bit of Future over the stained area and that fixes it.
