ARC Discussion Forums: Scale conversion - FWD to RWD - ARC Discussion Forums
#1 User is offline   Matt_S
  • Hopes to complete a model kit someday
  • Member ID: 297
Posted 26 April 2012 - 01:02 PM
Has anyone done this before? If so, how did you do it?
Matt B)
#2 User is offline   Netz
  • Where am I going, and what am I doing in this hand basket
  • Member ID: 2585
Posted 26 April 2012 - 02:20 PM
Remove front axle and associated suspension, get donor car and swap mounts and A-Arm assembly.
Curt
#3 User is offline   Matt_S
  • Member ID: 297
Posted 29 April 2012 - 08:25 AM
Sounds like a plan - I guess the hard part would be finding a good donor kit.
Thanks for your help.
Matt B)
#4 User is offline   Netz
  • Member ID: 2585
Posted 29 April 2012 - 02:38 PM
Sorry it wasn't much help, also after re-reading your title, FWD meant Front wheel drive and not Four Wheel drive, I'm kinda stuck in 4x4 right now.
What exactly are you trying to convert, it might help if you explain your conversion,it's hard to guess since I'm not sitting at your work bench.
Curt
#5 User is offline   Matt_S
  • Member ID: 297
Posted 02 May 2012 - 11:19 AM
This kit: http://www.internetm...ll_citation.htm
Matt B)
#6 User is online   Bigasshammm
  • From The Skies We Conquer.
  • Member ID: 19195
Posted 02 May 2012 - 12:38 PM
I would say all you'd really need to source is a driveshaft and the rear suspension bits. Look for an old Camaro or basically any type of cheap rwd car. Heck you could probably even use the pieces from a NASCAR kit but that would be a beefy rear end then.
Will the kit accommodate the shaft or will you have to cut and scratch in a new housing?
Depending on the kit's engine you'll probably want a transmission as well. Might have serious fit issues though.
#7 User is offline   Matt_S
  • Member ID: 297
Posted 06 May 2012 - 04:11 AM
One thing I was thinking about was finding a suitable chassis from another kit and swapping it in (so far, the best on I've found is from the Revell BMW 320i, but it's in 1/25 scale, and may be too narrow. Am checking on some 1/24 BMW kits.
I was also considering an AWD conversion as well
Matt B)
This post has been edited by Matt_S: 06 May 2012 - 04:25 AM
