ARC Discussion Forums: Tamiya 1/35 M1025 Humvee - ARC Discussion Forums
Tamiya 1/35 M1025 Humvee Custom build
#1 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 22 April 2012 - 12:53 AM
Having just finished the Academy M1511 Humvee, I had so much fun I wanted to do another Humvee. This time i'd thought I would be a bit creative and do a bit of a "what if" using the simpler but still excellent Tamiya kit, which represents an older variant- perfect for my plans.
You see, I know I'll never own a real Humvee so I figure a model will as close as I'll get :). Why not have some fun and make my fantasy hunting Humvee! Hunting, hiking, biking and camping are my other hobbies and I thought this would be a fun way to tie them all together.
Everything just falls together like butter and in 3-hours I was ready to paint:
This post has been edited by toadwbg: 22 April 2012 - 01:13 AM
#2 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 22 April 2012 - 01:06 AM
I'm using all Tamiya paints and trying to use up some surplus colors: Dark Yellow for the base exterior
NATO black for the undercarriage:
Build tip: assemble and liquid glue (Tenax) as much of the undercarriage as you can ahead of painting. No problem getting the black into all the nooks and crannies.
This post has been edited by toadwbg: 22 April 2012 - 01:14 AM
#3 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 22 April 2012 - 01:17 AM
Camo: I want to do an outdoors hunting camo. I don't want to try and reproduce Realtree Hardwoods or Mossy Oak but rather something resembling a custom paint job you would see on a aluminum flat-bottomed duck boat. You know, the kind a duck hunter painted with a spray can in his garage or back yard. There are several examples where I live LOL!
After doing a little research and going thru my Tamiya paint bottles in the stash, I settled on something resembling WW2 Panzer "spot" camo. I did a little testing on the upper hatch here:
I like the direction! Need to refine it a little and work on getting some cleaner spots- too much overspray. I think that's due to my old and worn/bent airbrush needle and tips. I got some brand spankin new ones I'll swap in and give another go.
#4 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 22 April 2012 - 02:56 AM
Had to sneak back into the man-cave after I put the kids to sleep to lay down the camo! Here it goes:
First, XF-58 Olive Green
Than, XF-64 Red Brown
I'm sorta liking it :cheers:
#5 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 22 April 2012 - 03:04 AM
Wheels on and tape off:
#6 User is offline   B-17 guy
  • oooo piece of candy!
  • Member ID: 12053
Posted 22 April 2012 - 04:12 PM
Nice! Almost needs bulkenzreuze.
#7 User is offline   skuki
  • Member ID: 3466
Posted 22 April 2012 - 05:41 PM
Hahaha, indeed :D
Nice paintjob toadwbg!
#8 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 22 April 2012 - 06:24 PM
I thought the same- a Balkenkruze! Might look cool on the inside of the rear hatch! LOL!
#9 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 01 May 2012 - 01:19 AM
Updates:
#10 User is offline   toadwbg
  • Supergenius!
  • Member ID: 514
Posted 03 May 2012 - 04:22 AM
Got the special MREs packed, need more!
#11 User is offline   HWR MKII
  • Member ID: 13649
Posted 14 June 2012 - 12:36 AM
if possible repl;ace the rubber tires in the kit. They may dryrot after about 3 years
