Ok, so now i'm realizing that my inexperience is beating me up
!!! Gluing the forward fuselage together is resulting in a couple of problems... I should've done a bit more dry fitting cuz I knew the turtle deck wasn't fitting correctly, but I thought I'd force it to fit while gluing.....
Problem #1)The gaps on the sides of the deck... I added some plastic hoping to blend later....
Problem#2)The tub should've been 2mm forward, so I sanded those two plastic strips that go along the canopy locks to make it fit
And third, the nose gear bay was off 1mm so I added a piece of plastic here and super glued the gap by the join
Hopefully after paint and nose gear is on this area will be hidden.... If any of you guys know what to do about the turtle deck please give me some input... I am hoping the photo etch set has the strips that go along the canopy locks....I hope that this model doesn't win in the end
