ARC Discussion Forums: B-17 Reference Information - ARC Discussion Forums
  • 15 Pages +
B-17 Reference Information All the Technical Data & Tips
#1 User is offline   Kostucha
  • Hangin' on the props...
  • Member ID: 15874
Posted 28 December 2010 - 10:28 PM
Folks,
This pinned thread here is intended for anyone who has any helpful information on B-17's (ranging from the 299 to all other variants), that can be of use. If you've got a question, by all means post it up here, we can try to get the answer for you too.
With reference to B-17 model products and info, I ask that you keep that within your own build thread.
Cheers!
Mark.
This post has been edited by Kostucha: 28 December 2010 - 10:30 PM
#2 User is offline   100th BG
  • Member ID: 12902
Posted 28 December 2010 - 10:37 PM
I'll start, what the heck: There are NO screens in the intakes of the B-17. Yes, I know the B-17 currently flying in the Memphis markings has them. Now the oil coolers (between the engine nacelles) are a different story! :unsure: And those two tubes are for the battery vents. This is on the right side between the fuselage and the #3 engine. There is only one battery on the left side.
This post has been edited by 100th BG: 28 December 2010 - 10:39 PM
#3 User is offline   100th BG
  • Member ID: 12902
Posted 28 December 2010 - 10:41 PM
Here is the oil cooler. It has a couple of screens in front of it. They are slightly staggred and each covers a little over half of the opening. This was so that if ice were to build up on them, there would still be airflow to the cooler. Sorry it is kind of dark. The horizontal mesh is the ice screen.
This post has been edited by 100th BG: 28 December 2010 - 10:42 PM
#4 User is offline   Kostucha
  • Member ID: 15874
Posted 28 December 2010 - 10:42 PM
Karl,
Thanks for starting us out!
If one were to take a flashlight and shine it down in there (in the air intakes from your first picture), what would be found or seen?
Cheers!
Mark.
This post has been edited by Kostucha: 28 December 2010 - 10:42 PM
#5 User is offline   100th BG
  • Member ID: 12902
Posted 28 December 2010 - 10:48 PM
View PostKostucha, on Dec 28 2010, 04:42 PM, said:
Karl,
Cheers!
Mark.
The (unpainted) ducting runs back a ways and then turns. How far back depends on the engine:
#6 User is offline   Kostucha
  • Member ID: 15874
Posted 28 December 2010 - 10:49 PM
Here are a few quick links, threads that within them had a lot of great information:
LMM research page with a lot of great info on what happens in the hangars.
The First GB Thread where near the end there was some great information as well
Phils hints on searching for B-17 images as well as a bit of info on the noses of B-17's
Thread on B-17 Stencils
Quick blurb on the Chin Turrets and colour
#7 User is offline   richter111
  • Devoid of ANY Social Life
  • Member ID: 220
Posted 29 December 2010 - 05:22 AM
Here is a good one for battle damaged B-17 units
http://www.daveswarbirds.com/b-17/
#8 User is offline   richter111
  • Member ID: 220
Posted 29 December 2010 - 05:40 AM
Another forum, loaded with stories, and more, plenty of time to be wasted here
Seems to populated by WWII vets as well, good for asking those pesky questions
http://forum.armyairforces.com/Heavy-Very-...mbers-f155.aspx
#9 User is offline   100th BG
  • Member ID: 12902
Posted 29 December 2010 - 09:37 AM
Mark, weren't you asking about what was under the cockpit floor? Here is the view aft under the top turret:
#10 User is offline   Shawn M
  • Slave to the plastic
  • Member ID: 17738
Posted 29 December 2010 - 02:05 PM
wow this is great! thanks gang.
I dont have much to add as most of my research is on my PC, not the web.
http://www.luchtoorlog.be/b17.htm
This site is great, the thread is long and loads slowly but some great images!
http://www.warbirdinformationexchange.org/...=26&t=29083
This post has been edited by Shawn M: 29 December 2010 - 02:28 PM
#11 User is offline   Kostucha
  • Member ID: 15874
Posted 29 December 2010 - 03:46 PM
I was indeed asking. I'm a little confused on the placement though - I was under the impression that the floor was flat under the top turret, and aft of that it'd be the bomb-bay. I am so confused right now...
#12 User is offline   majortomski
  • Member ID: 4964
Posted 29 December 2010 - 04:03 PM
A good friend of mine runs this site:
http://www.aerovintage.com/b17bits.htm
Author of several B-17 books. He likes to document the history of the remaining eleven flying aircraft.
#13 User is offline   Kostucha
  • Member ID: 15874
Posted 29 December 2010 - 04:20 PM
A quick shot from the training fields where maintainers were learning how to do engine swaps of the Wright-Cyclone R-1820's... or so I thought... I started looking closer and saw that she's still got her 50's, as well as what's in the back ground... looks more and more like a full our swap of 4 of the radials on an active war time bomber. If anyone's got any more info on this one it'd be greatly appreciated.
I'm putting this picture up mainly to show the 6 engines, and the 4 exposed firewalls:
Cheers,
Mark.
#14 User is offline   Kostucha
  • Member ID: 15874
Posted 29 December 2010 - 07:22 PM
Would anyone be able to post up a good shot or information on what is found at the joint between the wings and the fuselage? Specifically, what is on the aft portion if you were to remove the wings.
Thanks in advance,
Mark.
This post has been edited by Kostucha: 29 December 2010 - 07:22 PM
#15 User is offline   Shawn M
  • Member ID: 17738
Posted 29 December 2010 - 07:28 PM
mark, hit that wix link I posted (2nd one) its got what you need and then some i think
#16 User is offline   Kostucha
  • Member ID: 15874
Posted 29 December 2010 - 07:33 PM
Yup! Thanks Shawn! Holy Crow there's a lot of stuff there!
#17 User is offline   Shawn M
  • Member ID: 17738
Posted 29 December 2010 - 09:55 PM
yeah its a treasure trove!
#18 User is online   Bigasshammm
  • From The Skies We Conquer.
  • Member ID: 19195
Posted 30 December 2010 - 03:41 PM
So I remembered years ago I picked up this obscure DVD on ebay entitled "How to Fly The B-17". I've never actually watched it but it's supposed to be like an old army training video. I guess I'll throw it in now and see what it's about.
#19 User is offline   Shawn M
  • Member ID: 17738
Posted 30 December 2010 - 05:21 PM
What!? :thumbsup: I watch stuff like that as soon as it hits my house!
#20 User is offline   richter111
  • Member ID: 220
Posted 30 December 2010 - 07:52 PM
Those flight check series are really interesting
I also have the one for fighters
  • 15 Pages +
