AnthonyWan, on Sep 24 2009, 03:04 AM, said:
Can't wait to see your take on this one Ken! It's definitely on my to-buy list along with the Global Voyager single jet aircraft that flew around the world with Steve Fossett.
(Have you seen that one?
-Awan
I have seen, but haven't made Global Voyager - not really might scene (it doesn't have red stars)....
I'm only doing SS1 because I was asked to......
Meanwhile, some more progress....
White Knight engine parts - jet engine assembled at top.....
...anyone know why the engine is so exposed ???
Cockpits painted - they look like they are composite material in the few photos I have from the Internet - so I painted them matt black with gloss black bits - then dry-brushed to highlight.
I added some colour to the instrument binnacle and straps from tape. Not much is going to be seen through those tiny portholes...
SS1 with rocket motor installed - I'm not sure why the 'jetpipe' doesn't extend all the way to the rear - but a 'bell shaped' nozzle is supplied to hide it all.
I cleaned and then dipped both nose glazing parts in Kleer (Future)... this is White Knight with its glazing fitted...
.... same for SS1 - I added a plastic card 'shelf' around the fuselage rim to give the glazing something to rest on...
Here they are both together - I had trouble finding 'top dead centre' on the nose glazing - the portholes are marked with raised lines - but I could only just make them out...... you try counting
sixteen (?) tiny, faint raised lines on clear plastic
There is now a slight step between the glazing and fuselage - which will have to be filled and rubbed down to eliminate all traces of the joint.
It's coming along nicely though..... but I am dreading masking those porholes.
I am thinking of ways to do it - maybe leftover Eduard wheel hub masks?? - but I need to find plenty all the same right size
Maybe try to cut out my own circles from Tamiya masking tape - but how ?? suitable diameter brass rod sharpened to make a punch ??
All ideas welcomed......
Ken
