ARC Discussion Forums: 1/20 F-16 - A scratch build project - ARC Discussion Forums
  • 7 Pages +
#1 User is offline   regevmo
  • Member ID: 4779
Posted 09 October 2007 - 10:15 PM
I started a scratch build project that most likely would be a long one.It will be an F-16, but i still haven't decided yet on a specific version (big chance it will be a "C" model).My goal is to do a 100% scratch build F-16 using all kind of materials and techniques. The aircraft will be built with options to open different panels and many things will be decided as i will advanced in this build. Every help and comments will be appreciated as i definitely will need it in some areas.
The first thing i'm "attacking" is the station number 5 pylon that holds the 300 gallon fuel tank (and ALQ-??? variants).I chose to start with this part because it is common to all versions and it is a relatively a simple shape and will give me the opportunity to test some of the materials.
The pylon is shown in this photo -
The materials:
A plastic plate -
Balsa wood -
3 different kind of glue's :
1. Home made glue (Thinner mixed with plastic)
2. Humbrol glue
3. Cyanoacrylate (The thin type)
The home made glue was used to glue the first layer of plastic to the balsa wood, and then a second layer of plastic was glued using the humbrol one and the cyano glue to add some strength.
This is the part after this process and a little bit of sanding -
Few hours after gluing the plastic i found that in some areas the plastic was melting (maybe i used to much glue) so i will use putty to fix it -
This is part of the "holding mechanism" (not completed yet) -
So this is it, every journey begins in one small step :o
Hope to update soon,
Regev
#2 User is offline   CorsairMan
  • Member ID: 8119
Posted 09 October 2007 - 10:18 PM
Excellent! This is a big project and you are smart to start with small bites!
#3 User is offline   AnthonyWan
  • Ad astra per aspera
  • PipPipPipPipPipPipPipPipPipPip
  • Member ID: 5747
Posted 09 October 2007 - 10:30 PM
This could be interesting....:o
will be keeping a close eye :wierdo:
AW
#4 User is offline   Aggressor Supporter
  • Member ID: 5408
Posted 09 October 2007 - 11:52 PM
This is a most interesting project. Watching with interest.
#5 User is offline   jmel
  • Hopeless Recluse
  • Member ID: 773
Posted 11 October 2007 - 01:15 AM
Wow! What a project! I can't wait to see how you progress.
The Viper carries the ALQ-184, ALQ-131, and ALQ-188. The -188 is shown in the photo.
Jake
#6 User is offline   hazmatt
  • Supermoto Junkie
  • Member ID: 7302
Posted 11 October 2007 - 03:24 AM
Man that thing is going to be sweet. That's one hell of a scratch build project. Will be following!
Matt
#7 User is offline   Su-34
  • San Sanovich
  • Member ID: 7095
Posted 11 October 2007 - 08:27 AM
Its going to be BiG and AMAZING!
Im following this build with intrest..
#8 User is offline   stelios2000
  • Member ID: 4257
Posted 11 October 2007 - 01:11 PM
i am with you .........
hope to manage your BIG F-16!!!!
#9 User is offline   Phartycr0c
  • Member ID: 7900
Posted 11 October 2007 - 08:57 PM
1/20th eh? my thats going to be a big bird!
Watching with keen interest.
#10 User is offline   regevmo
  • Member ID: 4779
Posted 12 October 2007 - 08:52 AM
Thanks for the kind words guys :cheers:
Jake
Thanks jake, but i think (i need to check it thought) that the ALQ-131 have a different pylon and if so then i will build this pylon also. I'm planning to be able to switch load configuration on the F-16.
Man, with so many ideas i have for this build it should get it own manual (Dash-??? ...) :worship:
Regev
#11 User is offline   regevmo
  • Member ID: 4779
Posted 13 October 2007 - 04:33 PM
New Update -
After using putty on some areas and a lot of sanding i started the scribing process using different kind of tools -
Right side -
Left Side -
Bottom -
The part is almost done (little things will be added later) and here is a comparison to a 1/72 pylon -
Next step is primer painting.
Regev
#12 User is offline   jmel
  • Hopeless Recluse
  • Member ID: 773
Posted 13 October 2007 - 07:03 PM
You're correct. The -131 requires a special centerline pylon due to ground clearance. It cannot be carried on the standard pylon you're building.
However, that pylon is perfectly acceptable for the ALQ-184 pod.
Jake
#13 User is offline   regevmo
  • Member ID: 4779
Posted 26 October 2007 - 01:26 PM
New update:
Painted all the pylon parts with primer color which showed a few problems with the scribing of the main part, it will be fixed and will be painted again –
First try to make the 'Remove Before Flight' tag:
First printed the tag (two sides) –
Then using self Adhesive Aluminum foil to glue the two sides of the tag –
Made a ring and the safety pin from thin copper wire -
Here it is inserted to its place on the pylon –
Started to work on the 300 gallon fuel tank, first i made the base from balsa wood –
Then wrapped the wood with plastic –
I'm using milliput (standard grade) as the first layer of filler and I must say I love this stuff, it has two parts that you mix and then after allowing 3-4 hours to dry you can start the sanding –
Still a lot of work to do –
Regev
#14 User is offline   stelios2000
  • Member ID: 4257
Posted 26 October 2007 - 01:28 PM
incredible !!!!!
#15 User is offline   PhantomMan
  • Member ID: 10933
Posted 26 October 2007 - 01:45 PM
View Poststelios2000, on Oct 26 2007, 03:28 PM, said:
incredible !!!!!
It's AMAZING!!!! :wub: B)
#16 User is offline   regevmo
  • Member ID: 4779
Posted 01 November 2007 - 01:26 PM
New update –
Work on the fuel tank continues, I made some kind of homemade 'mr. surfacer' using green putty and acetone –
"painted" the fuel tank with this stuff –
Finished sanding and ready for painting –
After painting with primer, still need to fix few areas –
Next step will be detailing this part.
Also made a punch & die set that will be needed in the future (especially in the cockpit ) –
This tool was made according to a great guide by user named ModelDay, you can see the guide here –
Link
Regev
#17 User is offline   Flying Penguin
  • You can call me Al.
  • Member ID: 7354
Posted 01 November 2007 - 04:42 PM
Now this I want to see.... I'll be following this closely :wub:
Looking good so far!
:wub:
Jamie
#18 User is offline   PhantomMan
  • Member ID: 10933
Posted 01 November 2007 - 05:13 PM
Looking very good so far! :woot.gif:
#19 User is offline   afterburner
  • Resident glue sniffer.
  • Member ID: 4095
Posted 01 November 2007 - 05:18 PM
Dude- I am gonna be glued to this... nice work so far!!!!
#20 User is offline   regevmo
  • Member ID: 4779
Posted 21 November 2007 - 06:22 AM
New update –
Made different holes for the connection points and hoses that will be added later –
Made the fuel cap and the part that connect the fuel tank to the tail hook –
Some of the small parts are ready to be painted –
I got the Tamiya 1/32 F-16CJ that will be my guideline trough the building so here a comparison between the 1/20 & the 1/32 –
I want to do the screws heads like in the picture below, I tried to do it with cyno glue but the result wasn't good (not consistent size) so if you have any idea on how to do it i will appreciate the help -
Regev
  • 7 Pages +
2 User(s) are reading this topic
0 members, 2 guests, 0 anonymous users
